[Proj] New OSGeo website should rename Proj4 to Proj
Thomas Knudsen knudsen.thomas at gmail.com
Fri Jan 12 01:01:56 PST 2018
Roger, these numbers are not assumed to match - cf. e.g.
https://autotools.io/libtool/version.html
which says: "For what concerns the version of the ABI, it should not,
generally, be tied to the release version;"
And please check the entire text of what I propose: The name *is* indeed
PROJ, according to that, it's just a matter of keeping PROJ.4 as the name
of the *project*, and having *PROJ* as the *product*. This is a.o. in order
to keep a reasonable connection to the URL of the proj4.org web presence (
proj.org is not available)
You may disagree with me, but if you do so strongly, please volunteer to
carry out the rebranding.
2018-01-12 9:03 GMT+01:00 Roger Oberholtzer <roger.oberholtzer at gmail.com>:
> On Thu, Jan 11, 2018 at 3:01 PM, Kristian Evers <kreve at sdfe.dk> wrote:
> >> Isn't it a premature call?
> >> As discussed on the proj list [0][1][2], the "4" in the PROJ.4 name
> >> should be de-emphasized, since the next major release will be PROJ
> >> v5.0.0.
> >> Please rename the project on the new website from "Proj4" to "Proj".
> I agree about the name being simply Proj. My reasoning:
> The release numbers don't match the API/ABI version. Proj 4.9.3 is
> actually 12. What is being called the 5.x series will go through a few
> version numbers. Keeping these two independent sets of numbers
> straight is always a source of error.
> One set of numbers to rule them all...
> Roger Oberholtzer
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180112/fce81d4a/attachment.html>
