[Proj] Correction of definition of CRS EPSG 5456 and 5457
Eduardo Rojas Rodríguez eduardo.rojas at soltig.net
Sun Jan 21 18:51:03 PST 2018
Hi Andre
sorry for bothering you again
I have read extensively all the information you have given me and I have
come to the following conclusions:
1. according to
https://gis.stackexchange.com/questions/253475/results-of-layers-created-with-a-custom-crs-are-loaded-with-a-generated-crs-in-q/254087#254087
and
http://geotiff.maptools.org/proj_list/lambert_conic_conformal_2sp.html
By having proj LCC 1SP with a scale factor is basically the same as LCC 2SP.
so the definition within PROJ4
+ proj = lcc + lat_1 = 10.46666666666667 + lat_0 = 10.46666666666667 + lon_0
= -84.33333333333333 + k_0 = 0.99995696 + x_0 = 500000 + y_0 = 271820.522 +
ellps = clrk66 + towgs84 = 205.96, -98.0.0.0.0 + units = m + no_defs
is correct since it determines lat_1 equal to lat_0
is this correct?
1. Regarding the "toWGS84" + towgs84 = 205.96, -98.0,0.0.0
is a concatenation (via NAD27) of the transformations 6888 and 1171 imported
from GDAL when using this transformation I get a displacement of 2mm
3. + towgs84 = 213.116,9.358, -74.946 are within the transformation EPSG ::
5470 Coordinate Transformation [Ocotepeque 1935 to WGS 84 (1)] which is more
general and I get displacements of 8 meters
As far as I can deduce, the definition is adequate both when using LCC1
which is equal to LCC2 with the scale factor.
the only thing then is to ask the EPSG for a transformation of EPSG :: 5470
Coordinate Transformation [Ocotepeque 1935 to WGS 84 (1) more presiding
using 7 parameters. maybe?
I would like to know what you think of my conclusions, so I can tell you how
much I have learned from PROJ4 and EPSG.
Thank you very much for all the help and everything I've learned
Analista en SIG
Soluciones en Tecnologías
Tel: 506 2505-5453
http://soltig.net
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
