[Proj] Converting between true north, grid north, and magnetic north
Charles Karney charles.karney at sri.com
Tue Jan 30 07:03:15 PST 2018
GeographicLib https://geographiclib.sourceforge.io provides access to
several magnetic models via the MagneticField utility.  E.g.,
   echo 42.363 -71.006 | MagneticField -t now
   -14.67 67.08 20228.0 19569.1 -5121.1 47840.0 51940.7
The first number is the current magnetic declination at Boston Logan
Airport using the wmm2015 magnetic model.
The magnetic models need to be downloaded separately from the
GeographicLib library using
   geographiclib-get-magnetic
On 01/30/18 06:42, Chen Barnoy wrote:
> Hi,
> Is there a way to convert between grid north, true north and magnetic
> north in Proj4 or another library?
> Cheers,
> Chen
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
