[Proj] [proj] Migration from travis-ci.org to travis-ci.com
Even Rouault even.rouault at spatialys.com
Fri Jun 1 12:03:54 PDT 2018
On vendredi 1 juin 2018 18:51:44 CEST Kristian Evers wrote:
> Awesome. That should speed things up a bunch! Thanks for taking care of
> this.
> Maybe related to this change, I have noticed that the website is not being
> deployed properly at the moment. That is, it isn’t being deployed at all.
> Previously this has been caused by failure to generate the PDF docs but I
> can’t find any hints in the logs that that is the problem. I am wondering
> if maybe the switch to the .com domain has had an effect on the deploy key
> or something like that?
ah indeed, they warned me that the settings are lost during the migration, so
they key should be re-installed / re-generated.
I indeed see 2 (hidden) encrypted environement variables at
https://travis-ci.org/OSGeo/proj.4/settings
but none at
https://travis-ci.com/OSGeo/proj.4/settings
Looking at travis/add_deploy_key.sh, I guess they are the secret elements to
be able to decode the encrypted RSA private key associated with the "proj.4
deploybot" fake user.
It looks like it is Howard that has the needed elements to reinstall them.
Even
> /Kristian
> > On 1 Jun 2018, at 17:21, Even Rouault <even.rouault at spatialys.com> wrote:
> > Hi,
> > Thanks to OSGeo financial support, repositories under the OSGeo github
> > organizations have now a maximum 13 concurrent jobs available on
> > travis-ci.com
> > Note that the builds are now on the .com domain, and no longer on the
> > .org.
 This is related to their on-going migration from the .org to the
> > .com. The logs of the builds on .org are still available, but no new
> > builds won't be triggered on the .org now.
> > So head to:
> > 	https://travis-ci.com/OSGeo/gdal/
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
