[Proj] Testing framework
Kurt Schwehr schwehr at gmail.com
Fri Jun 8 08:08:54 PDT 2018
Thanks Even, Mat, and all,
I will keep writing more tests as I get time.
For the record, code in gdal-autotest2 is under Apache 2.0.  When I commit
that code to PROJ it will still be copyright google, but it will be under
that PROJ license as documented in
https://github.com/OSGeo/proj.4/blob/master/COPYING
I will follow the file top comment style that Even did in basic_test.cpp.
-kurt
On Fri, Jun 8, 2018 at 4:07 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> to conclude that thread, we finally decided for Google Test. Now both
> integrated with automake & cmake.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180608/20483439/attachment.html>
