[Proj] PROJ 5.0.0RC6
Kristian Evers kreve at sdfe.dk
Thu Mar 1 10:18:46 PST 2018
I’ve been thinking about this all day. Initially I was planing to add the fix to the map server problem, but it is not
particularly smart to add stuff without an RC I guess. The current release candidate seems to behave quite well,
apart from that one thing which has a known work-around. I’ll plan for a patch release around April 1st. If the
number of reported bugs is low I’ll consider not issuing 5.0.1.
I’ll get to work on packing 5.0.0.
/Kristian
> On 1 Mar 2018, at 19:07, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 03/01/2018 06:39 PM, Kristian Evers wrote:
>> Well, I was sort of going to play It by ear with regards to patch releases. 5.1.0 will be around June 1st.
>> But maybe it isn’t such a bad idea to already schedule the first pure bug-fixing release in a month time or so.
>> Jeff’s (well.. my bug, discovered by Jeff) could then be applied in that release instead of sneaking
>> It in the final release. The vote promoting RC6 to final has more or less passed on the MetaCRS list
>> less than an hour ago.
>> See the release schedule here: https://github.com/OSGeo/proj.4/milestones?direction=asc&sort=due_date&state=open
>> What are your thoughts on that?
> The next release in June is quite reasonable, although not strictly a
> bugfix release.
> If there aren't many regressions reported before that time, leaving the
> planned release dates as-is is probably fine.
> Otherwise scheduling a bugfix release before that time, 4-6 weeks after
> the 5.0.0 release, is probably a good idea.
> Kind Regards,
> Bas
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
