[Proj] checks failing on Linux
Roger Oberholtzer roger.oberholtzer at gmail.com
Fri Mar 9 03:49:25 PST 2018
When I run make checks, I get the failure at the end of this listing.
I have no idea why. I am running the tests in the build tree (I have
not done a make install), if that matters.
make[3]: Entering directory '/tmp/proj-5.0.0/test/gie'
PROJ_LIB=../../nad ../../src/gie 4D-API_cs2cs-style.gie
Reading file '4D-API_cs2cs-style.gie'
total:  4 tests succeeded, 12 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie GDA.gie
Reading file 'GDA.gie'
total:  3 tests succeeded,  0 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie axisswap.gie
Reading file 'axisswap.gie'
total: 27 tests succeeded,  0 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie builtins.gie
Reading file 'builtins.gie'
total: 1315 tests succeeded,  0 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie deformation.gie
Reading file 'deformation.gie'
total:  5 tests succeeded,  4 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie ellipsoid.gie
Reading file 'ellipsoid.gie'
total: 30 tests succeeded,  0 tests skipped,  0 tests failed.
PROJ_LIB=../../nad ../../src/gie more_builtins.gie
Reading file 'more_builtins.gie'
pj_cart_selftest fails with 64
total: 44 tests succeeded,  4 tests skipped,  1 tests FAILED!
Makefile:470: recipe for target 'more_builtins' failed
make[3]: *** [more_builtins] Error 1
Roger Oberholtzer
