[Proj] Convert MODIS Sinusoidal to WGS84
Juergen Stumpe jstumpe.ho at gmail.com
Tue Mar 27 03:13:58 PDT 2018
Hello,
I'm trying to convert Modis meter values to WGS84 decimal degrees,
using the PROJ4 command line, but I'm not able to set the parameters
correctly.
E.g. the command "echo 4447802.078667 -1111950.519667 | cs2cs
+proj=sinu +to +proj=WSG84" fails with "projection initialization
failurecause: Unknown error".
Does anybody know how the define the PROJ4 command line properly, in
order to achieve a conversion with parameters according the attached
TWCC screen shot?
Thanks in advance!
Juergen
Name: TWCC Screen Shot.PNG
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180327/4da51bde/attachment.png>
