[Proj] Regression 5.1.0 -> 5.2.0 ?
Søren Holm sgh at sgh.dk
Sun Nov 4 13:42:40 PST 2018
Hi
Great - I look forward to the response fomr Thomas or Kristian.
Regarding the ressource files. What can be expected as far at compatability?
For my use case having new versions of the resource files be compatible with
old proj-versions would be appropriate. For other people it might be opposite.
søndag den 4. november 2018 21.51.26 CET skrev Even Rouault:
> Søren,
> I think the issue is that the _TC32_TD32 definition in the DK file has a
> Helmert transform that lacks the convention used for rotation terms, which
> is required since PROJ 5.2. So likely adding convention=coordinate_frame
> would fix the issue (since that was what was implemented before PROJ 5.2),
> but I'll Kristian or Thomas check that this is appropriate.
Søren Holm
