[Proj] Regression 5.1.0 -> 5.2.0 ?
Kristian Evers kreve at sdfe.dk
Sun Nov 4 23:58:27 PST 2018
Here:
<_TC32_TD32>
    proj=pipeline no_defs
    step proj=cart ellps=GRS80
    step proj=helmert inv
         x = -81.0703   rx = -0.48488
         y = -89.3603   ry = -0.02436
         z =-115.7526   rz = -0.41321   s = -0.540645
         convention=coordinate_frame                                         #  <--- HERE
    step proj=cart ellps=intl  inv      # Now: GEO_TD32
    step proj=utm  ellps=intl  zone=32  # And now: TC32_TD32 (UTM32 if ED50 was "perfect")
Ignore my previous comment about replacing +transpose - it's not there so can't be replaced. I think this will work for you.
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På vegne af Søren Holm
Sendt: 5. november 2018 08:45
Til: proj at lists.maptools.org
Emne: Re: [Proj] Regression 5.1.0 -> 5.2.0 ?
Yes, but where exactly should I add "convention=coordinate_frame" ?
mandag den 5. november 2018 08.40.44 CET skrev Thomas Knudsen:
> Søren,
> I suppose Even's suggestion will solve your problem - but could you please
> tell  whether that is the case?
> (just to avoid chasing solutions for problems already solved).
Søren Holm
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
