[Proj] Regression 5.1.0 -> 5.2.0 ?
Kristian Evers kreve at sdfe.dk
Mon Nov 5 00:09:46 PST 2018
Awesome. Fixed in https://github.com/NordicGeodesy/NordicTransformations/commit/97de170da47d9ffc5430ce00298617c75f80085e
It will be included in the next release of proj-datumgrid-europe.
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På vegne af Søren Holm
Sendt: 5. november 2018 09:03
Til: proj at lists.maptools.org
Emne: Re: [Proj] Regression 5.1.0 -> 5.2.0 ?
It works! :)
mandag den 5. november 2018 08.58.27 CET skrev Kristian Evers:
> Here:
> <_TC32_TD32>
>     proj=pipeline no_defs
>     step proj=cart ellps=GRS80
>     step proj=helmert inv
>          x = -81.0703   rx = -0.48488
>          y = -89.3603   ry = -0.02436
>          z =-115.7526   rz = -0.41321   s = -0.540645
>          convention=coordinate_frame
> #  <--- HERE step proj=cart ellps=intl  inv      # Now: GEO_TD32
>     step proj=utm  ellps=intl  zone=32  # And now: TC32_TD32 (UTM32 if ED50
> was "perfect")
> Ignore my previous comment about replacing +transpose - it's not there so
> can't be replaced. I think this will work for you.
> /Kristian
> vegne af Søren Holm Sendt: 5. november 2018 08:45
> Yes, but where exactly should I add "convention=coordinate_frame" ?
> mandag den 5. november 2018 08.40.44 CET skrev Thomas Knudsen:
> > Søren,
> > I suppose Even's suggestion will solve your problem - but could you please
> > tell  whether that is the case?
> > (just to avoid chasing solutions for problems already solved).
Søren Holm
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
