[Proj] WGS84 to NAD27 Coordinate conversion in Android
Martin Desruisseaux martin.desruisseaux at geomatys.com
Wed Nov 14 05:59:13 PST 2018
Hello Rob
Le 14/11/2018 à 14:51, Robb Main a écrit :
> I was hoping to find an operational (or easily ported) Android
> solution, and less of a swiss-army knife codebase. You covered these
> issues in your response, and SIS / GDAL may yet prove usefull in the
> eventual solution. I'm still hopeful that there might be a simpler
> solution, not yet suggested (and that I've not yet discovered).
No problem. I'm not sure if it has been pointed out in previous replies,
but another good source is:
    https://geographiclib.sourceforge.io/
It provides both C++ and Java implementations of the same algorithm, and
part of those C++ algorithms are actually integrated into Proj.4.
    Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20181114/2da03610/attachment.html>
