[Proj] converting WGS84/ETRS89 to ITM/OSGM15
Thomas Knudsen knudsen.thomas at gmail.com
Mon Sep 3 06:28:29 PDT 2018
Elmir,
Before considering a PR, please make sure that the OSGM15 material is
freely distributable
/Thomas
Den man. 3. sep. 2018 kl. 12.18 skrev Elmir Jagudin <elmir.jagudin at gmail.com
> On Thu, Aug 23, 2018 at 10:41 AM Elmir Jagudin <elmir.jagudin at gmail.com>
> wrote:
>> On Wed, Aug 22, 2018 at 12:12 PM Alain Orsoni <Alain.Orsoni at ign.fr>
>> wrote:
>>> Hi,
>>> Trying to answer with my knowledge :
>>> On my computer I can do this transform in this way
>>> echo -6.6 53 21 | cs2cs +init=epsg:4326 +to +proj=tmerc +lat_0=53.5
>>> +lon_0=-8 +k=0.99982 +x_0=600000 +y_0=750000 +ellps=GRS80
>>> +towgs84=0,0,0,0,0,0,0 +geoidgrids=egm08_25_rg.gtx +units=m +no_defs
>>> 693972.63 695281.52 -35.37
>>> The result is a little bit different from what you expect. Maybe because
>>> I use egm08 and you expect another Geoid model.
>> Aha, cool. This looks like the right path for me.
>> Yes, the OSGM15 is probably using slightly different geoid model. I'll
>> try to create gtx file for OSGM15.
> After creating a GTX table for OSGM15, the height calculations look
> correct. Thanks for help Alain and Even!
> Is it possible to contribute these GTX files, so they are included into
> future proj4 releases?
> Should I make a PR to this repo: https://github.com/OSGeo/proj-datumgrid ?
> The tables are here for now:
> https://github.com/elmirjagudin/gri2gtx
> Best Regards,
> Elmir
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180903/68826495/attachment.html>
