[Proj] PROJ 5.2 RC1
Kristian Evers kreve at sdfe.dk
Tue Sep 11 03:58:45 PDT 2018
Thanks Marco,
This was also discovered by Sebastian who quickly submitted a fix: https://github.com/OSGeo/proj.4/pull/1114
Sebastian also submitted a few other fixes. If no other problems are found I will issue RC2 Wednesday evening (European time).
/Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På
> vegne af Marco Atzeri
> Sendt: 11. september 2018 12:42
> Til: proj at lists.maptools.org
> Emne: Re: [Proj] PROJ 5.2 RC1
> Am 10.09.2018 um 20:33 schrieb Kristian Evers:
> > All,
> > I have just uploaded release candidates for PROJ 5.2,
> > Please download and test the various candidates within the next couple
> > of days. I plan to issue
> > the final release on Saturday the 15th given that the feedback from the
> > RC’s are positive by then.
> > /Kristian
> noted on cygwin that the shared library name is going backward
> 5.1.0 is cygproj-13.dll
> 5.2.0RC1 is cygproj-12.dll
> There is a wrong progression from
> libproj_la_LDFLAGS = -no-undefined -version-info 14:0:1
> to
> libproj_la_LDFLAGS = -no-undefined -version-info 14:0:2
> The LibTool version number is usually given in the form
> current:revision:age. This means that:
> - If interfaces have been changed or added, but binary compatibility has
> been preserved, change to current+1:0:age+1
> - If binary compatibility has been broken, e.g. due to removed or
> changed interfaces, change to current+1:0:0
> - If the interface is the same as the previous version, change to
> current:revision+1:age
> So assuming that compatibility is not broken
> it should be or 15:0:2 or 14:1:1
> as both will give cygproj-13.dll
> Regards
> Marco
> cygwin package maintainer
> Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
> https://www.avast.com/antivirus
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
