[Proj] PROJ 5.2.0
Kristian Evers kreve at sdfe.dk
Mon Sep 17 00:53:49 PDT 2018
Roger,
Probably, yes. Could you share some details on how you got there? Did you use make or CMake?
/Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På
> vegne af Roger Oberholtzer
> Sendt: 17. september 2018 09:46
> Til: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
> Cc: news_item at osgeo.org; metacrs at lists.osgeo.org
> Emne: Re: [Proj] PROJ 5.2.0
> I just tried building this on Linux with g++, and I dot this:
> >[   37s] checking whether g++ supports C++11 features with -h std=c++11...
> no
> >[   37s] configure: error: *** A compiler with support for C++11
> Shouldn't the test
>      -h std=c++1
> be
>      -std=c++11
> Roger Oberholtzer
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
