[Proj] PROJ 5.2.0
Kristian Evers kreve at sdfe.dk
Mon Sep 17 06:00:22 PDT 2018
Yeah, we recently introduced the googletest suite which is C++ based. Hence the new requirement. That should probably have been specified in the release notes now that I think of it...
Are you all set now that you've updated your spec file or do we need to make some changes that will ease things for you and others with later releases?
/Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På
> vegne af Roger Oberholtzer
> Sendt: 17. september 2018 11:08
> Til: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
> Emne: Re: [Proj] PROJ 5.2.0
> On Mon, Sep 17, 2018 at 9:55 AM Kristian Evers <kreve at sdfe.dk> wrote:
> > Roger,
> > Probably, yes. Could you share some details on how you got there? Did you
> use make or CMake?
> My mistake. I see that 5.2.0 now requires g++. I did not add that to
> my spec file. I thought it was a default thing in the build
> environment. Seems not.
> If you are curious, I try to maintain builds here:
> https://build.opensuse.org/package/show/home:rogeroberholtzer/proj
> These are the platforms I test for. There are others that are also supported.
> Roger Oberholtzer
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
