[Proj] Compiling Proj 5.2.0
Roger Oberholtzer roger.oberholtzer at gmail.com
Tue Sep 18 03:32:40 PDT 2018
On Tue, Sep 18, 2018 at 8:27 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> > Do you mean that there will not be a C interface to the new PROJ? Or
> > you are meaning that PROJ itself will be c++11, but with a C API for
> > client programs to use. I am guessing/hoping the later.
> Was discussed in
> http://lists.maptools.org/pipermail/proj/2018-May/008214.html
> and related thread
Point 3:
- Part of that C++ externally accessible API *might* also be exposed
through new
C API
So I am guegsing that whatever can currently be done in the C API will
continue. New things available via the c++ interface are undecided.
Roger Oberholtzer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180918/e229a5da/attachment.html>
