[PROJ] definition string with units=minutes?
Wendell.CTR.Turner at faa.gov Wendell.CTR.Turner at faa.gov
Thu Apr 4 08:31:01 PDT 2019
Is there a way to define a conversion string with "units=minutes"?  Also, positive longitude indicates west.
That is, for an input of:
    2446 4431
The output would be:
    40.76667 -73.85000
I'm guessing it would look something like:
    +proj=latlong +datum=WGS84 +units=minutes
But it seems that the only angular definition for units is 'units=degrees'.
BTW, is this the correct forum for this type of question?
Thank you,
Wendell
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190404/3578a075/attachment.html>
More information about the PROJ mailing list
