[PROJ] [PROJ 6.0.0] Different behaviors for creating a transformation of type EPSG:9616
Even Rouault even.rouault at spatialys.com
Tue Apr 30 11:18:14 PDT 2019
On mardi 30 avril 2019 17:53:13 CEST Didier Richard wrote:
> Ok, in that case, two more questions :
> 1.- why not returning a PROJ_OBJ_LIST for proj_create_crs_to_crs to get a
> clearer API (and let the user choose amongst transformations) ?
To be honest, the new behaviour of having several candidate coordinate
operations is a late addition. Initially, it picked up only one, but that was
not ideal.
Another reason is that want proj_create_crs_to_crs() to remain the "easy" way
of using the PROJ API, so returning a PJ* object directly usable by
proj_trans() and friends, so it is not a bad thing that this complexity
remains hidden from the user point of view.
> 2.- how to get the inner projections (proj_crs_get_coordoperation does not
> seem the right one) ?
Basically proj_create_crs_to_crs() is a high level function over
proj_create_operations(). So if you need fine grained control of which
coordinate operation you want to use exactly, use proj_create_operations()
Even
http://www.spatialys.com
More information about the PROJ mailing list
