[PROJ] CRS JSON
Even Rouault even.rouault at spatialys.com
Fri Aug 9 10:07:51 PDT 2019
On lundi 8 juillet 2019 12:57:16 CEST Even Rouault wrote:
> Hi,
> following a recent Tweeter discussion, I've taken a crack at implementing a
> JSON representation for CRS objects, based on the ISO_19111:2019
> abstract model and compatible with WKT2:2019.
> See my proposal in https://github.com/OSGeo/PROJ/pull/1547
OK, so now import&export of PROJJSON has been implemented in this PR.
Examples:
Import from EPSG and export as PROJJSON:
$ projinfo EPSG:32631 -o PROJJSON -q > out.json
Import from PROJJSON and export as a old school PROJ string:
$ projinfo @out.json -o PROJ -q
+proj=utm +zone=31 +datum=WGS84 +units=m +no_defs +type=crs
$ cat out.json
  "type": "ProjectedCRS",
  "name": "WGS 84 / UTM zone 31N",
  "base_crs": {
    "name": "WGS 84",
    "datum": {
      "type": "GeodeticReferenceFrame",
      "name": "World Geodetic System 1984",
      "ellipsoid": {
        "name": "WGS 84",
        "semi_major_axis": 6378137,
        "inverse_flattening": 298.257223563
    "coordinate_system": {
      "subtype": "ellipsoidal",
      "axis": [
          "name": "Geodetic latitude",
          "abbreviation": "Lat",
          "direction": "north",
          "unit": "degree"
          "name": "Geodetic longitude",
          "abbreviation": "Lon",
          "direction": "east",
          "unit": "degree"
    "id": {
      "authority": "EPSG",
      "code": 4326
  "conversion": {
    "name": "UTM zone 31N",
    "method": {
      "name": "Transverse Mercator",
      "id": {
        "code": 9807
    "parameters": [
        "name": "Latitude of natural origin",
        "value": 0,
        "unit": "degree",
        "id": {
          "code": 8801
        "name": "Longitude of natural origin",
        "value": 3,
        "unit": "degree",
        "id": {
          "code": 8802
        "name": "Scale factor at natural origin",
        "value": 0.9996,
        "unit": "unity",
        "id": {
          "code": 8805
        "name": "False easting",
        "value": 500000,
        "unit": "metre",
        "id": {
          "code": 8806
        "name": "False northing",
        "value": 0,
        "unit": "metre",
        "id": {
          "code": 8807
    "subtype": "Cartesian",
    "axis": [
        "name": "Easting",
        "abbreviation": "E",
        "unit": "metre"
        "name": "Northing",
        "abbreviation": "N",
        "unit": "metre"
  "area": "World - N hemisphere - 0°E to 6°E - by country",
  "bbox": {
    "south_latitude": 0,
    "west_longitude": 0,
    "north_latitude": 84,
    "east_longitude": 6
  "id": {
    "code": 32631
Even
http://www.spatialys.com
More information about the PROJ mailing list
