[PROJ] Vector Data Reprojection
ivay ivaygis at protonmail.com
Tue Aug 20 02:11:30 PDT 2019
I have a shape file with epsg 4612.
I converted it into new shapefile with epsg 4326.
When I opened both shape files (with 4612 and 4326 epsg codes), there is no change in the X and Y locations.
Does both shapefiles (with epsg 4612 and 4326 codes) have same X and Y values?
My requirement is to convert the original file with "epsg code 4612" exactly into the "epsg 4326" .
Thank you for your ideas.
Ivay
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190820/acd8be50/attachment.html>
More information about the PROJ mailing list
