[PROJ] OGC blog post summarising Web-mapping misalignment problem
Roger Oberholtzer roger.oberholtzer at gmail.com
Thu Aug 22 07:19:37 PDT 2019
On Thu, Aug 22, 2019 at 3:23 PM Duncan Agnew <dagnew at ucsd.edu> wrote:
> I can only speak to ITRF, but the changes in this come mostly from there being longer time series and more stations. Motion
> of the Earth's center of mass is at the sub-cm level--and at this level there are actual motions of the ground that enter in, from
> loading by water changes, or by postglacial rebound. That said, if your country is all on one plate, and your national authority
> has defined a CRS moving with that plate (a plate-fixed system) then that is probably the one to use, since it maximizes the future
> relevance of a value that doesn't include an epoch.
But I'm still not 100% clear how to define my source WGS84 lat/longs
from my GNSS receiver when doing this. How best to know which WGS84 to
use? The local CRS cannot know this. Or so it seems to me.
Roger Oberholtzer
More information about the PROJ mailing list
