[PROJ] Seeking clarification on PROJ support for temporal transformations
Even Rouault even.rouault at spatialys.com
Tue Aug 27 13:28:20 PDT 2019
On mardi 27 août 2019 20:12:27 EEST Kristian Evers wrote:
> Nyall,
> The epoch of a coordinate, e.g. the time it was measured, has nothing to do
> with the CRS definition.
 But it is important once you want to transform
> from one CRS to another or propagate the coordinate through time in the
> same CRS. Coordinates in a dataset will not necessarily have the same
> measuring time/epoch, which is why it is not a good idea to store that
> information alongside the CRS description. This is why 4D coordinates are
> necessary for dynamic CRS's. You need a XYZT geometry, as it were.
> There are of course exceptions, for instance a raster image where all pixels
> are captured simultaneous by the sensor. For that it would be nice to have
> a way to register the capture time in a standardized way. I am not sure if
> this is already possible with WKT2:2018.
The COORDINATEMETADATA[] WKT2:2018 construct I showed in the first reply to
this thread would be a way to do that. That construct is not acknowledged as a
CRS by itself but a pair consisting of a CRS + a coordinate epoch
http://www.spatialys.com
More information about the PROJ mailing list
