[PROJ] Seeking clarification on PROJ support for temporal transformations
Nyall Dawson nyall.dawson at gmail.com
Tue Aug 27 14:25:37 PDT 2019
On Wed, 28 Aug 2019 at 01:26, Even Rouault <even.rouault at spatialys.com> wrote:
> > But, if I understand correctly, WKT2:2018 would be the ultimate answer
> > to this, in that it would allow us to specify the epoch of a dataset
> > as an integral part of the data's CRS definition (which it is).
> Not sure to understand your "what it is", but pedantically, the epoch of the
> dataset is not part of the CRS definition. Anyway...
I concede this point -- the specs clearly are in your favour:
16.1: "Coordinate epoch is not part of a CRS definition, it is
additional metadata for the coordinates which is required to ensure
that they are unambiguous when referenced to a dynamic CRS."
Nyall
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the PROJ mailing list
