[PROJ] Seeking clarification on PROJ support for temporal transformations
Even Rouault even.rouault at spatialys.com
Tue Aug 27 14:50:14 PDT 2019
> A global plate motion model is part of ITRF2014 [0]. It comes in the form of
 Euler pole rotation parameters. They can be used in a time-dependent
> Helmert Transformation. Some time ago I included all the parameters in the
> ITRF2014 init file [1]. I use them to transform data from ITRF2014 to the
> local Greenlandic frame GR96 (effectively ITRF94 at 1996.623). I've defined a
> pipeline like this:
> proj = pipeline ellps = GRS80
>             step inv init = ITRF2014:ITRF94 t_obs = 1996.623
>             step inv init = ITRF2014:NOAM   t_epoch=1996.623
That's interesting !
I believe there's a small mistake in the ITRF2014 file (or the IGN page might
have been updated in the meantime) for the ITRF2014:ITRF94 entry. It lacks a
+drz=0.00002 (the ITRF96 entry as well). I can see it in http://itrf.ign.fr/
doc_ITRF/Transfo-ITRF2014_ITRFs.txt and it is also there in the EPSG dataset:
$ projinfo -s ITRF2014 -t ITRF94 -o PROJ -q
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert
+xy_in=deg +xy_out=rad +step +proj=cart +ellps=GRS80 +step +inv +proj=helmert
+x=-0.0074 +y=0.0005 +z=0.0628 +rx=0 +ry=0 +rz=-0.00026 +s=-0.0038 +dx=-0.0001
+dy=0.0005 +dz=0.0033 +drx=0 +dry=0 +drz=-2e-05 +ds=-0.00012 +t_epoch=2010
+convention=position_vector +step +inv +proj=cart +ellps=GRS80 +step
+proj=unitconvert +xy_in=rad +xy_out=deg +step +proj=axisswap +order=2,1
(the signs are different due to EPSG having ITRF94 to ITRF2014 natively, and
thus PROJ applying a +inv)
Another detail: the pipeline you mention above is from GR96 to ITRF2014, right
(due to the 'inv' of ITRF2014:ITRF94) ?
And the last step which I assume is for the northamerica plate motion doesn't
seem to have any effect as you forced t_obs in the previous step to the
t_epoch of that step, so the time difference is 0.
$ echo " 2768773.7909  -1598552.2935  5500477.1338" | src/cct +proj=pipeline
+ellps=GRS80 +step +inv +init=ITRF2014:ITRF94 +t_obs=1996.623
 2768773.7710  -1598552.2904  5500477.1757
+ellps=GRS80 +step +inv +init=ITRF2014:ITRF94 +t_obs=1996.623 +step +inv
+init=ITRF2014:NOAM +t_epoch=1996.623
Even
http://www.spatialys.com
More information about the PROJ mailing list
