[PROJ] Seeking clarification on PROJ support for temporal transformations
Joel Haasdyk joel.haasdyk at customerservice.nsw.gov.au
Wed Aug 28 04:05:31 PDT 2019
Indeed,
Any regular tectonic plate motion can be expressed as a 3 parameter Euler Pole, which can in turn be expressed in the familiar Helmert 14 (15) parameter transformation format, as three Cartesian axial rotation rates (all other components equal 0).
See https://geodesy.noaa.gov/PUBS_LIB/NOAA_TR_NOS_NGS_0062.pdf
See http://www.quickclose.com.au/StanawayetalREFAGppt.pdf
Case in point are these:
EPSG:: 8049 GDA2020 <=> ITRF2014, with reference epoch 2020.0)
EPSG::8448 GDA2020 <=> WGS84(G1792), with 'parameter reference epoch' @2020.0)
Where GDA2020 is essentially a snapshot of ITRF2014 at 2020.0.
So EPSG can and does publish time-dependent transformations...
(this is not new, e.g. EPSG::8078 ITRF2000 <=> ITRF2014 for example)
...just not (yet) explicitly from CRS_A(@epoch1) to CRS_A(@epoch2). I could be wrong.
However... EPSG::8049 gives you all the info you need to transform from
ITRF2014(@epoch1) <=> ITRF2014(@2020.0) <=> ITRF2014(@epoch2)
Joel Haasdyk
Message: 5 from Digest 20
Date: Wed, 28 Aug 2019 00:50:14 +0300
To: Kristian Evers <kreve at sdfe.dk>
Cc: Nyall Dawson <nyall.dawson at gmail.com>, PROJ <proj at lists.osgeo.org>
Subject: Re: [PROJ] Seeking clarification on PROJ support for temporal
	transformations
Message-ID: <2096164.pDk9JYgsY7 at even-i700>
Content-Type: text/plain; charset="us-ascii"
> A global plate motion model is part of ITRF2014 [0]. It comes in the form of
 Euler pole rotation parameters. They can be used in a time-dependent
> Helmert Transformation. Some time ago I included all the parameters in the
> ITRF2014 init file [1]. I use them to transform data from ITRF2014 to the
> local Greenlandic frame GR96 (effectively ITRF94 at 1996.623). I've defined a
> pipeline like this:
> proj = pipeline ellps = GRS80
>             step inv init = ITRF2014:ITRF94 t_obs = 1996.623
>             step inv init = ITRF2014:NOAM   t_epoch=1996.623
Also copied from Archive:
>Even Rouault even.rouault at spatialys.com
>Tue Aug 27 08:26:57 PDT 2019
>That would probably be the best solution.
>> Is this being blocked by
>> the EPSG registry itself and lack of means of encapsulating the
>> transformation parameters?
>Good questions. I dont't have definite answers.
>The EPSG registry doesn't publish time-dependent transformations for CRS A to
>CRS A currently, except for the Canadian NAD83(2011) CRS. Not sure if this is
>a lack of interest, or data, or just that this isn't yet done, but will come
>in future releases of the database.
>I've heard there are global plate motions models, but haven't investigated
>what they look like (grids, parametric models... ?) and if they are available
>for "free". Otherwise you could also have models using methods like Helmert on
>a per-area basis.
This email message and any attached files is confidential and intended solely for the use of the individual or entity to whom it is addressed and may contain information that is privileged, confidential and/or exempt from disclosure under applicable law. If you have received this email in error, delete all copies and notify the sender.
This email is subject to copyright. No part of it should be reproduced, published, communicated or adapted without the copyright owner's written consent. No employee or agent is authorised to conclude any binding agreement on behalf of the Department of Customer Service (DCS) by email without express written confirmation.
The views or opinions presented in this email are solely those of the author and do not necessarily represent those of the DCS. DCS accepts no liability for any loss or damage arising from the use of this email and the recipient should check this email and any attached files for the presence of viruses.
More information about the PROJ mailing list
