[PROJ] How to construct proper cs2cs command line arguments
Jean Louis bugs at gnu.support
Sun Dec 1 02:11:18 PST 2019
* Kristian Evers <kreve at sdfe.dk> [2019-11-25 13:23]:
> Jean Louis,
> Take a look at the documentation for cs2cs. I believe it should answer all your questions regarding cs2cs.
> Here it is: https://proj.org/apps/cs2cs.html
Dear Kristian,
So I chose for example input coordinate system EPSG:4326 and output
EPSG:21036 and then on https://mygeodata.cloud/cs2cs/ I have selected
that, and used coordinate: -1.122159, 29.714413 for which I get the
result: -2897602.84658;13830181.544
and same result I cannot get by using:
$ cs2cs EPSG:4326 EPSG:21036
-3394656.76	9852263.62 0.00, 29.714413
What is then wrong?
Jean
More information about the PROJ mailing list
