[PROJ] Using +nadgrids with cs2cs (version 4.9.3)
Chris Crook ccrook at linz.govt.nz
Sun Dec 1 23:41:56 PST 2019
Hi
I am trying to configure a cs2cs command line to use the New Zealand NTv2 grid to convert from NZGD49 to NZGD2000.
I have tried several variants of the command below, but so far none have resulted in the output coordinates being different
from the input coordinates?
Please can anyone offer suggestions as to what would work?
echo '173 -41 0' | cs2cs -v -f %.10f +proj=latlong +ellps=GRS80 +to +proj=latlong +datum=nzgd49  +nadgrids=nzgd2kgrid0005.gdb
# ---- From Coordinate System ----
#Lat/long (Geodetic alias)
# +proj=latlong +ellps=GRS80
# ---- To Coordinate System ----
# +proj=latlong +datum=nzgd49 +nadgrids=nzgd2kgrid0005.gdb +ellps=intl
#--- following specified but NOT used
# +towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
173.0000000000  -41.0000000000 0.0000000000
Thanks
Chris
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the PROJ mailing list
