[PROJ] (Angular/Linear/Scale) speed in C++ API
Martin Desruisseaux martin.desruisseaux at geomatys.com
Mon Dec 2 13:12:38 PST 2019
Le 02/12/2019 à 20:06, Even Rouault a écrit :
> Yes. But is there really an un-ambiguous interpretation of OGC
> 01-009... ? I doubt so: isn't that the reason for WKT2 ?
I think it is mostly (not completely) unambiguous. At least the units of
measurements of PRIMEM and PARAMETER elements were clearly defined [1].
Some confusion that I saw in the past was caused by the fact that GEOGCS
(for GeographicCRS) and GEOCCS (for GeocentricCRS) keywords are too
similar (they differ only by a "G" versus "C" letter). The difference is
so easy to miss that a past GDAL/PROJ maintainer concluded that OGC
01-009 was self-contradicting, and thus went away with his
interpretation in GDAL. But it was an (understandable) misreading of the
specification rather than a specification inconsistency.
OGC 01-009 was ambiguous in some aspects, for example the projection
parameter names were not defined except for a short list of map
projections, but units of measurements was not an OGC 01-009 ambiguity
(it was an OGC 99-049 ambiguity however - I think this is the origin of
the problem). But the reality was that no matter what OGC 01-009 said,
the software implementations were heterogeneous regarding their
compliance to that specification. Because we had no way to distinguish
whether a WKT 1 string is compliant with OGC O1-009 or not, we had to
create new keywords for making clear that a WKT is using the OGC 01-009
rules for units of measurements. Other reasons for creating WKT 2 were
because WKT 1 was based on a conceptual model that predated ISO 19111,
for erasing the use of WGS84 as an universal hub, and because of WKT 1
ambiguities other than units of measurements.
>> If yes, what is the difference between
>> WKTFormatter::Convention::WKT1_GDAL and
>> WKTFormatter::Convention::WKT1_ESRI?
> A lot... CRS names, datum names, ellipsoid names, projection method
> names, parameter names. No AUTHORITY[] or AXIS[] nodes in WKT1_ESRI.
> Basically WKT1_ESRI is what you find in shapefile .prj files
Ah okay, the differences are in the naming and in the presence of
AUTHORITY/AXIS elements. Thanks, I will update documentation. Thanks
also for the example.
     Martin
[1] http://www.geoapi.org/3.0/javadoc/org/opengis/referencing/doc-files/WKT.html#PRIMEM - this is copied verbatim from OGC 01-009.
More information about the PROJ mailing list
