[PROJ] NTv1/NTv2/CTable2 and west-oriented longitude shifts
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Tue Dec 10 00:58:49 PST 2019
Hi Even,
I agree. Please, abandon the strange conventions of NTv2 and use east positive, normal column ordering and preferably also decimal degrees instead of arcseconds.
I would prefer very accurate (0.1 mm) grid shift files and an encoding that makes it simple to write and read it. To me this is more important than the best possible data compression. So if possible, use signed integers with no offset (0 is no correction) and 1*10^-9 degree as (default) unit.
By the way, GeoTIFFs also have a map projection. I assume you are planning to use latlon thus platte-carree projection. It would be interesting to also allow other projections (with 1*10^-4 metre as (default) unit). Although this is against ISO, it would make it possible for countries that use horizontal grid shifts on projected coordinates to implement their transformation in PROJ., so they don't have to redefine their national coordinate system like the Netherlands did to accomplish this.
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ mailing list
