[PROJ] Affine transformation in proj < 6?
Tammo Jan Dijkema t.j.dijkema at gmail.com
Thu Dec 12 04:31:37 PST 2019
Hi all,
I'm new to proj, so sorry if this is a trivial question (I've read through docs for an hour without finding an answer, so it can't be too trivial).
I have a custom coordinate system, which is defined through an affine transformation from ETRS89. All coordinates I care about are in xyz Cartesian coordinates. In particular, to get pqr coordinates, I do
coords_pqr = (coords_etrs - pqrorigin_etrs) * (3x3 matrix)
Now I'm generating raster images in PQR, which I would like to store in GeoTiff, so if I understand correctly I need to write a proj string into the GeoTiff to describe the projection. More background: I'm writing the PQR-images in python, and want to export them so that I can load them into QGIS, with appropriate coordinates.
I see that an affine transformation is part of proj6, but I cannot expect users to have that installed. Is there a way to abuse another projection to achieve the same thing?
If there is another channel to ask this question, please let me know. Thanks in advance!
Tammo Jan Dijkema
More information about the PROJ mailing list
