[PROJ] Odd 6.3.0RC1 issue
Roger Bivand Roger.Bivand at nhh.no
Mon Dec 30 09:22:34 PST 2019
On Mon, 30 Dec 2019, Even Rouault wrote:
>> You can't. GetAttrValue() is about asking value of WKT(1) nodes, of PROJ.4
>> string
> I meant *not parts* of PROJ.4 string
No, but I can (and do) retreive DATUM and TOWGS84 from objects
instantiated when reading vector files to check whether they vanish from
proj4 strings.
Status is that legacy R-sp-workflows and modern R-sf-workflows will move
to WKT2 as the internal CRS representation, but in the R-sp-workflow case,
PROJ4 strings must be retained too, even though the WKT2 representations
will be used for transformation and file export. PROJ4 strings are also
needed to define CRS.
Here I'm just reporting a very puzzling issue. Checking across some other
EPSG, it seems to affect EPSG:27700 (the Snow Soho Cholera data set, the
Scottish lip cancer data set), and not in all contexts. However, the
problem was not present with 6.2.1, and is now.
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ mailing list
