[PROJ] Right way to do this transformation/projection : ITRF2014 -> WGS84 UTM
Even Rouault even.rouault at spatialys.com
Mon Dec 30 12:53:37 PST 2019
On lundi 30 décembre 2019 13:04:50 CET Julien Schroder wrote:
> Hello,
> First I want to apologize as this is a bit of a beginner question but after
> hours of experimentation I am still confused.
I find this is a rather advanced one :-)
You didn't specify which PROJ version you use. You might get different results
as we have refined such transformations over time.
Hint: the latest one will probably be the better.
> I have coordinates in ITRF2014 (both in geocentric and geodetic
> coordinates) with an associated EPOCH which I am trying to
> transform/project to WGS84 UTM18N using pyproj/PROJ and EPSG codes.
The "WGS84" datum as used by EPSG:4326, EPSG:4979 or any projected CRS based
on them such as EPSG:32618 is a "datum ensemble", that is one of the 6
possible realizations of the "WGS84 (Gxxxx)" datums, and the accuracy of
coordinates in this "datum ensemble" cannot be better than 2 meters, so you
should only get null transformations when transforming between it and
ITRF2014.
With PROJ 6.3, you'll get non-null transformations if transforming between
ITRF2014 and "WGS84 (G1762)" (*)
$ projinfo -s ITRF2014 -t "WGS 84 (G1762)" --spatial-test intersects --summary
Candidate operations found: 2
unknown id, Conversion from ITRF2014 (geog2D) to ITRF2014 (geocentric) +
Inverse of ITRF2008 to ITRF2014 (1) + Inverse of WGS 84 (G1762) to ITRF2008
(1) + Conversion from WGS 84 (G1762) (geocentric) to WGS 84 (G1762) (geog2D),
0.02 m, World
ITRF2014 to GDA2020 (1) + GDA2020 to WGS 84 (G1762) (1) + Conversion from WGS
84 (G1762) (geocentric) to WGS 84 (G1762) (geog2D), 0.201 m, Australia - GDA
> During my experimentation I noticed that doing EPSG 7789 => EPSG 32618
> holds different results (about 4cm diffrence) than  EPSG 7789  => EPSG 4919
> => EPSG 32614
Hum, doesn't make sense to me. Can you demonstrate this with PROJ command line
utilities ?
> Which surprised me as I thought that going from ITRF2014 to WGS84 involved
> a step through ITRF2000.
How did you see that ? In the above, the first result, which has worldwide
validity, goes from ITRF2014 to WGS 84 (G1762) through ITRF2008. Because there
is no direct transformation between ITRF2014 and WGS 84 (G1762) in the EPSG
dataset (I presume the reason is that WGS 84 (G1762) must have been defined
from ITRF2008)
Even
(*) well, this isn't completely true. If you try
projinfo -s ITRF2014 -t WGS84 --spatial-test intersects --summary
with latest PROJ 6.3, you'll get not-null transformations in the USA in the
Gulf of Mexico, but I think they are questionable as they involve a lot of
hoops through other CRS such as ITRF2008, NAD83(2011), NAD83 and NAD27 ! This
is due to latest EPSG database having a complex NAD27->ITRF2014 concatenated
operation for Gulf of Mexico (using the NAD83, NAD83(2011) and ITRF2008
intermediates), and thus it is chained with transformations from NAD27 to
WGS84...
http://www.spatialys.com
More information about the PROJ mailing list
