[PROJ] Vertical Transformations?
Greg Troxel gdt at lexort.com
Wed Feb 20 05:12:34 PST 2019
Even Rouault <even.rouault at spatialys.com> writes:
> With the vertconc.gtx grid available, you'll get
> $ echo "45 -100 100" | cs2cs -f "%.8f" EPSG:7406 EPSG:5500
> 44.99998071	-100.00039555 30.85853056
> Without it, you'll get just us-ft to metre for the vertical part:
> 44.99998071	-100.00039555 30.48006096
With the grids being in separate distribution files, it seems easy to
end up with them not installed.
I wonder if transformations that need grid files for correct behavior
should fail rather than skip the transformation, at least by default.
More information about the PROJ mailing list
