[PROJ] NTv2 grid file from Bessel ellipsoid to Bessel ellipsoid
Jochem jochem.lesparre at kadaster.nl
Mon Feb 25 05:14:19 PST 2019
Hi all,
Thanks for the quick reply, Even.
> Yes this is somewhat logical given what the code does
Ah, then the behaviour is different from what I expectated.
> For what you describe in your needs, you'd better use PROJ 5.2 or the
> nearly released PROJ 6.0 and use PROJ pipelines
I know, but I would like to be able to do the same with Proj.4, to share it
with the many users that still use this version.
> given what the code does (which of course is true of any bug :-)).
I thought it was a bug, since I also noticed that de code ignores the
setting for GS_TYPE in the header of de NTv2 (.gsb) file: if this is not set
to seconds, it still assumes seconds.
Anyway, thanks for the explanation. Now I am able to get what I need like
this with Proj.4:
cs2cs +proj=sterea +lat_0=52.156160556 +lon_0=5.387638889 +k=0.9999079
+x_0=155000 +y_0=463000 +ellps=bessel +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs +to +proj=longlat +ellps=bessel +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs -f %.9f < inputRD.txt > step1.txt
cs2cs +proj=longlat +ellps=WGS84 +wktext +nadgrids=rdcorr2018beta.gsb
+units=m +no_defs +to +proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0
+units=m +no_defs -f %.9f < step1.txt > step2.txt
(replace all heights by 0.0000)
cs2cs +proj=longlat +ellps=bessel
+towgs84=565.7381,50.4018,465.2904,-0.395026,0.330772,-1.876074,4.07244
+units=m +no_defs +to +proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
+units=m +no_defs -f %.9f < step2H0.txt > outputERS89.txt
which works for the entire world and within the bounding box of the grid it
gives the same (diff. < 1 mm) as:
+x_0=155000 +y_0=463000 +ellps=bessel +wktext +nadgrids=rdtrans2018beta.gsb
+units=m +no_defs -f %.9f < inputRD.txt > outputETRS89.txt
Kind regards, Jochem
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
More information about the PROJ mailing list
