[PROJ] Motion: Adopt RFC3 - Dependency management
Kristian Evers kreve at sdfe.dk
Wed Jan 16 07:53:34 PST 2019
Most of the code is now compiled as C++ so probably not a big issue in practical terms. Also, we do run all code through several msvc versions on AppVeyor so any non-msvs compliant code we may write should be discovered quickly. Code not passing the tests on AppVeyor should of course not be merged.
As far as I understand the material from Microsoft, they support a large subset of C99 but some lesser used features aren’t available. Getting a list of exactly what is and what isn’t supported is not easy to find though.
Just to be clear, I have no intention of updating the RFC as it is now. I don’t think the concerns raised here are incompatible with the content of RFC3.
/Kristian
Fra: Thomas Knudsen <knudsen.thomas at gmail.com>
Sendt: 16. januar 2019 16:12
Til: Kristian Evers <kreve at sdfe.dk>
Cc: Even Rouault <even.rouault at spatialys.com>; proj at lists.osgeo.org
Emne: Re: [PROJ] Motion: Adopt RFC3 - Dependency management
While improving, I think that the MSVC support of C99 is still incomplete, which could be a showstopper for going full C99
Den ons. 16. jan. 2019 kl. 15.46 skrev Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>>:
Well, we *could* do that, but since we already have a few functions that return int
instead of bool it would be more consistent to continue that pattern. I don't have
strong opinion on the matter. I am curious to know though if there is any users
of PROJ following the list that has a strict C89 requirement?
/Kristian
-----Oprindelig meddelelse-----
Fra: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sendt: 16. januar 2019 15:31
Til: proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>
Cc: Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>>
there's a point that came to mind suddenly. About C99 adoption, that mean that
we could use the 'bool' type in the C API for example. Do we want to do that ?
The adverse consequence would be for third-party code using PROJ API and
building with C89 only.
Even
> With +1 from Kristian, Even, Thomas and Howard I declare the motion passed.
> /Kristian
> Fra: Howard Butler <howard at hobu.co<mailto:howard at hobu.co>>
> Sendt: 14. januar 2019 16:08
> Til: Thomas Knudsen <knudsen.thomas at gmail.com<mailto:knudsen.thomas at gmail.com>>
> Cc: Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>>; PROJ <proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>>
> +1 Howard
> On Jan 14, 2019, at 5:26 AM, Thomas Knudsen
> <knudsen.thomas at gmail.com<mailto:knudsen.thomas at gmail.com><mailto:knudsen.thomas at gmail.com<mailto:knudsen.thomas at gmail.com>>> wrote:
> +1 Thomas
> Den man. 14. jan. 2019 kl. 12.14 skrev Even Rouault
> <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com><mailto:even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>>:
 On lundi
> 14 janvier 2019 10:20:11 CET Kristian Evers wrote:
> > PSC members,
> > RFC3 about dependency management has been up for review for quite some
> > time
 now. Since no comments has been reviewed since the last I update I
> > regard this as ready for a vote by the PSC.
> > The RFC is available here: https://github.com/OSGeo/proj.4/pull/1168
> > <https://github.com/OSGeo/proj.4/pull/1168>
> > I’ll start with my +1.
> +1 Even
> > /Kristian
> Spatialys - Geospatial professional services
> http://www.spatialys.com<http://www.spatialys.com/>
> PROJ mailing list
> PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org><mailto:PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>>
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190116/6551899f/attachment-0001.html>
More information about the PROJ mailing list
