[PROJ] How to apply Helmert trafo
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Mon Jun 17 00:30:52 PDT 2019
Dear Fabian,
For this transformation push/pop is not needed. That only makes sense in other situations, like when you use a geoid.
If the scale factor also differs from the primary source (EPSG is a secondary source), it should be adapted in the example to avoid confusion. If EPSG differs with the primary source, EPSG should be notified that there might be a mistake in their registry.
Kind regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Fabian Gross
Sent: Friday, June 14, 2019 3:41 PM
To: proj at lists.osgeo.org
Subject: [PROJ] How to apply Helmert trafo
Dear proj-members,
I would like to apply a Helmert trafo as part of a datum shift.
The example follows the EPSG geomatics guidance 7/2 (report 373-7-2):
From WGS72 (4984) -> WGS84 (4978).
There are 2 issues:
1. How to apply Helmert-Trafo? I.e.
  *   with or
  *   without the push/pop of the ellipsoidal height.
Only if it is not pushed/popped do the values fit to the reference and the direct/naive implementation of Helmert.
2. The scale parameters in the example (0.219) and the EPSG catalogue of pyproj (0.2263)  do not agree.
The attached file has the test case.
Kind regards
Fabian Gross
Telefon +49 (711) 648 71-995
_________________________________________________
sbp
schlaich
bergermann partner
Beratende Ingenieure
für erneuerbare Energie
Stuttgart . Berlin . New York
São Paulo . Shanghai . Paris
sbp sonne gmbh
Markus Balz Dipl.Ing. (FH)
Andreas Keil Dipl.Ing.
Schwabstrasse 43
70197 Stuttgart
Telefon +49 (711) 648 71-0
www.sbp.de<http://www.sbp.de/>
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190617/b315a2cb/attachment.html>
More information about the PROJ mailing list
