[PROJ] Meaning of (x) numbers in proj transformations in QGIS
Even Rouault even.rouault at spatialys.com
Sat Jun 29 03:27:36 PDT 2019
On samedi 29 juin 2019 16:06:47 CEST Nyall Dawson wrote:
> On Fri, 28 Jun 2019 at 19:03, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Another thing is that currently the import process of the EPSG dataset to
> > the PROJ dataset doesn't import remarks, so they are lost to the end
> > user. I didn't want to do that for now to limit the size of the database,
> > but that might be discussed.
> I'd be a big +1 to having access to these remarks through proj.
OK I've addressed this per
https://github.com/OSGeo/PROJ/pull/1537
http://www.spatialys.com
More information about the PROJ mailing list
