[PROJ] Transforming between ITRF realizations
Trey Stafford trey.stafford at nsidc.org
Fri May 3 10:23:17 PDT 2019
Hello,
I have a number of elevation datasets that each use a different ITRF
realization. The coordinates in these datasets are referenced to the
WGS84 ellipsoid. An example lon, lat, elev(meters above ellipsoid) tuple
would be:
-117.61748591770593, 59.496749040316935, 329.39612
According to the proj4 documentation on Helmert transformations
(https://proj4.org/operations/transformations/helmert.html), I should be
able to use something like this to convert between ITRF2000 and ITRF93:
proj +proj=helmert +convention=position_vector +x=0.0127 +y=0.0065
+z=-0.0209 +s=0.00195 +dx=-0.0029 +dy=-0.0002 +dz=-0.0006 +ds=0.00001
+rx=-0.00039 +ry=0.00080 +rz=-0.00114 +drx=-0.00011 +dry=-0.00019
+drz=0.00007 +t_epoch=1988.0
However, entering my coordinates yield the following result:
0.05    -0.01 329.39612
I've used proj4 previously, but not to do transformations between
different ITRF realizations. I suspect I am missing something, but I
have not had revelations yet. Any suggestions or insight would be
greatly appreciated!
Thanks,
Trey Stafford
More information about the PROJ mailing list
