[PROJ] PROJ >=5.0.0 on Travis CI
Michael Sumner mdsumner at gmail.com
Sun May 5 17:31:54 PDT 2019
Thanks Even, very helpful.
Cheers, Mike.
On Fri, May 3, 2019 at 6:30 PM Even Rouault <even.rouault at spatialys.com> wrote:
> On vendredi 3 mai 2019 11:32:40 CEST Michael Sumner wrote:
> > Hello, I'm trying  to install PROJ 5.0.0 or above with a Travis
> > configuration.
> > The only way I can get it to work is to build from source - does
> > anyone know a ppa/apt pathway to get PROJ >=5.0.0 that works in a
> > .travis.yml?
> A possibility is to build from source + ccache + enabling Travis caching of
> $HOME/.ccache + ./configure --disable-static . That should keep the time spent
> in PROJ building to a few seconds generally.
> https://github.com/OSGeo/proj.4/blob/master/.travis.yml#L9
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
More information about the PROJ mailing list
