[PROJ] PROJ 6.1.0RC1
Alan Snow alansnow21 at gmail.com
Mon May 6 16:08:59 PDT 2019
I tested RC1 with pyproj and all of our tests pass with the current
version. Thanks!
On Mon, May 6, 2019 at 2:21 PM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 5/6/19 8:02 PM, Even Rouault wrote:
> > ...OK, I didn't realize that the failures where not necessarily at the
> end of the log file...
> > 1) So one failure is:
> > Test:   01 Texel
> > Exec:   cs2cs EPSG:4937 +to EPSG:28992+5709 -f %.4f
> > Input:  53.160753042 4.824761912 42.8614
> > Output: 117380.1203   575040.3399 0.9985
> > Expect: 117380.1200   575040.3400 1.0000
> > NAP exceeds 0.001 meters: 0.00149999999999995
> > Test FAILED: From ETRS89 to RD/NAP - 01 Texel
> > I will save you the details and headaches, but the gist of the issue was
> that the vertical transformation
> > and horizontal transformation where applied in the wrong order.
> > There were 2 separate causes:
> > - the EPSG dataset doesn't register the interpolationCRS for "ETRS89 to
> NAP height (1)" vertical transformation (naptrans2008.gtx).
> >   According to the PDF you provided, this must be the Amersfoort datum.
> As this information is missing, the code assumes that
> >   the horizontal CRS to use for vertical transformation is ETRS89.
> > - The code didn't take properly into account the interpolationCRS for
> such geog3D <--> compoundCRS transformations
> > I've addressed both issues by the followup commit
> https://github.com/OSGeo/proj.4/pull/1454/commits/ae16cff6877a39903cd049491fbb1d96a4149a96
> > of
> > With that I now get
> > echo "53.160753042 4.824761912 42.8614" | PROJ_LIB=$PWD:data src/cs2cs
> -f %.15f EPSG:4937 +to EPSG:7415
> > 117380.120258881375776        575040.339879254694097 1.000069467784584
> > (instead of the custom compoundCRS "EPSG:28992+5709", you can
> equivalently use the registered compoundCRS of the EPSG database
> "EPSG:7415")
> That has become quite an impressive PR, thanks!
> > 2) For
> > Test:   07 No_rd&geoid
> > Exec:   cs2cs EPSG:28992+5709 +to EPSG:4937 -f %.9f
> > Input:  100000.6700 300000.8900
> > Output: 50.687420379  4.608971888 0.000000000
> > Expect: 50.687420405  4.608971812
> > Latitude exceeds 1e-08 degrees: 2.59999950458223e-08
> > Longitude exceeds 1e-08 degrees: 7.60000000710193e-08
> > Test FAILED: From RD/NAP to ETRS89 - 07 No_rd&geoid (Expected output
> overriden: *     * ^-?(\d+\.\d+|inf)$)
> > PROJ will indeed detect that the point is outside of the RD grid, and
> then it will use
> > the EPSG:15739 "Amersfoort to ETRS89 (3)" Helmert-based transformation.
> > $ echo "100000.6700 300000.8900 0" | src/cct -d 9 +proj=pipeline +step
> +inv +proj=sterea +lat_0=52.1561605555556 +lon_0=5.38763888888889
> +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +step +proj=push +v_3
> +step +proj=cart +ellps=bessel +step +proj=helmert +x=565.2369 +y=50.0087
> +z=465.658 +rx=0.406857330322398 +ry=-0.350732676542563 +rz=1.8703473836068
> +s=4.0812 +convention=coordinate_frame +step +inv +proj=cart +ellps=GRS80
> +step +proj=pop +v_3 +step +proj=unitconvert +xy_in=rad +xy_out=deg +step
> +proj=axisswap +order=2,1
> >  50.687420379    4.608971888   0.000000000           inf
> > I'm not sure how they get their expected result. It should be noted that
> proj 5.2.0 fails to transform in that case:
> > $ echo "100000.6700 300000.8900" |  ~/proj/install-proj-5.2.0/bin/cs2cs
> -f %.15f +init=rdnap:rdnap +to +init=epsg:4258
> > Rel. 5.2.0, September 15th, 2018
> > <cs2cs>: while processing file: <stdin>, line 1
> > pj_transform(): point not within available datum shift grids
> > *     * inf
> Like test 10 edge_rd, there are coordinates in the output, but exceeding
> the margin is ignored to allow the test to succeed. Because as the PDF
> documents: "... outside this region RD coordinates can be computed, but
> the output should be handled with care.". I don't consider this
> indications of issues in proj unlike the failures of the tests within
> the RD region. Many thanks for fixing those!
> I've added a patch with the changes from #1454 to the proj Debian
> package, and with that all the tests succeed again.
> Once Travis is happy about the changes, those changes will be included
> in RC2?
> Kind Regards,
> Bas
>  GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Alan Snow
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190506/688c0f23/attachment.html>
More information about the PROJ mailing list
