[PROJ] Possible error with +datum=potsdam and PROJ >= 5.0.0
Even Rouault even.rouault at spatialys.com
Tue May 7 12:46:25 PDT 2019
Alexander,
In PROJ 4.9.3 and earlier, +datum=potsdam expanded to
+ellps=bessel +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7
In PROJ 5.0.0 and later, +datum=postdam was changed to expand to
+ellps=bessel +nadgrids=@BETA2007.gsb
That is it will use the more precise BETA2007.gsb grid rather than the towgs84
clause, but this require the grid to be installed alongside other PROJ grids.
If not present, then no datum shift is done, hence the result you see.
So with PROJ 5.0.0 and later, you could get the same result as PROJ 4.9.3 if
you don't have the grid installed, by replacing "+datum=potsdam" with
"+ellps=bessel +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7"
(I don't understand why you'd get a correct result with just +ellps=bessel
without a +towgs84 or +nadgrids. That doesn't make sense to me)
With proj 5.2.0
$ echo "4395886.918912 5819485.694352" | cs2cs -f "%.4f" +proj=tmerc +lat_0=0
+lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
+towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7 +to +init=epsg:25832
599474.7609	5817502.6096 42.5689
With proj 6, things will work transparently:
- with BETA2007.gdb installed, you get exactly the result from the .csv file:
$ echo "4395886.918912 5819485.694352" | cs2cs -f "%.4f" EPSG:31464 EPSG:25832
599474.9342	5817502.6270 0.0000
- without it installed, it fallbacks to the Helmert transformation
599474.7609	5817502.6096 0.0000
Even
> Hi,
> we noticed differences in transforming geographic data from EPSG:31468
> to WGS 84 using ST_Transform on different PostGIS installations and it
> seems to come from different PROJ versions.
> For example, we have a point from CAD drawings of the Nuremberg subway
> network with the coordinates 4435877.4477166822 5475816.0547993957, so
> we know it must be on the train tracks.
> Converting this point using PROJ 4.9.3 gives us this point [1] with the
> coordinates 11.1148165905971 49.4159011654427 and using PROJ 5.0.1
> gives us this point [2] with the coordinates 11.1161576118633
> 49.4169712194789. However, updating the proj4text in the
> spatial_ref_sys table for the srid 31468 from
> +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +datum=potsdam
> +units=m +no_defs
> to
> +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
> on the PostGIS installation with version 5.0.1 of PROJ again gives
> correct results.
> PROJ version >= 5.0.0 seems to incorrectly handle conversions using
> +datum=potsdam. From [3] one can download test data to verify correct
> conversion from DHDN / GK to ETRS89 / UTM. Testing conversion of the
> value in line 7 of the downloadable CSV file [4] the results for PROJ
> version 4.9.3 and versions >= 5.0.0 differ. I have executed the
> following command using PROJ versions 4.9.3, 5.0.0, 5.1.0, and 6.0.0
> echo 4395886.918912 5819485.694352 | cs2cs +proj=tmerc +lat_0=0
> +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +datum=potsdam +units=m +no_defs +to
> +init=epsg:25832
> The output for 4.9.3 is:
> 599474.76	5817502.61 42.57
> The output for the other versions is:
> 599559.03	5817663.04 0.00
> Is this a bug in PROJ? And if so, what would be the recommended
> workaround?
> Kind Regards,
> Alexander Njemz
> [1]	https://www.google.de/maps/place/49%C2%B024'57.2%22N+11%C2%B
> 006'53.3%22E/@49.4158889,11.1126169,751m/data=!3m2!1e3!4b1!4m5!3m4!1s0x
> 0:0x0!8m2!3d49.4159012!4d11.1148166
> [2]	https://www.google.de/maps/place/49%C2%B025'01.1%22N+11%C2%B
> 006'58.2%22E/@49.4169722,11.113978,750m/data=!3m2!1e3!4b1!4m5!3m4!1s0x0
> :0x0!8m2!3d49.4169712!4d11.1161576
> [3]	http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/de_dhdn2etr
> s_beta.php
> [4]	http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/BETA2007tes
> tdaten.csv
http://www.spatialys.com
More information about the PROJ mailing list
