[PROJ] Projection for Sandwell et al.'s topex topo and grav files?
Kurt Schwehr schwehr at gmail.com
Wed May 8 08:11:17 PDT 2019
Thanks!  I'll be investigating more today.  Monica Schwehr mentioned that
you have a different Earth radius than she was seeing in the GMT code
base.  I'll follow up on that after I get a chance to look through GMT head
and GMT 4 more.
On Tue, May 7, 2019 at 6:52 PM <jmfluis at gmail.com> wrote:
> The IMG grids are spherical Mercator inches so there is likely no EPSG or
> WKT that represents that. But you can do all the work in GMT.
> 1- Convert to netcdf, maintaining the Merc projection, but change the
> origin to (0,0) (it was in the LL corner). That’s the role of -C
> img2grd -R-180/180/-80/80 topo_19.1.img -Gspherical-mercator-proj.grd -T1
> -D -M -C
> 2- Edit the header to convert the inches to Mercator meters. The grid
> above has x_min = -180; x_max = 180.
> And that corresponds to 6378137 *2pi = 4.007501668557849e7  meters. So we
> can compute a scale factor of
> 111319.49079327358 = 6378137 *2pi / 360
> and apply it to the region in degrees.
> [-180 180 -139.6 139.6] .* 111319.49079327358 = -20037508.3427892
> 20037508.3427892 -15540200.914741 15540200.914741
> So finaly use grdedit to change the limits and assign it a proj4 string
> describing the projection
> grdedit spherical-mercator-proj.grd
> -R-20037508.3427892/20037508.3427892/-15540200.914741/15540200.914741
> -J"+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137 +units=m
> +no_defs"
> You can now confirm with gdalinfo
> C:\v>gdalinfo spherical-mercator-proj.grd
> Warning 1: dimension #1 (x) is not a Longitude/X dimension.
> Warning 1: dimension #0 (y) is not a Latitude/Y dimension.
> Driver: netCDF/Network Common Data Format
> Files: spherical-mercator-proj.grd
> Size is 21600, 16752
> Coordinate System is:
> PROJCS["unnamed",
>     GEOGCS["unnamed ellipse",
>         DATUM["unknown",
>             SPHEROID["unnamed",6378137,0]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433]],
>     PROJECTION["Mercator_1SP"],
>     PARAMETER["central_meridian",0],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["Meter",1]]
> Origin = (-20037148.342789199000000,15540200.914741000000000)
> Pixel Size = (1855.324846554555500,-1855.324846554560700)
> Metadata:
>   grid_mapping#spatial_ref=PROJCS["unnamed",
>         DATUM["unknown",
>     UNIT["Meter",1]]
>   NC_GLOBAL#Conventions=CF-1.7
>   NC_GLOBAL#description=Spherical Mercator Projected with -Jm1
> -R-180/180/-80.0023237126/80.0023237126
>   NC_GLOBAL#GMT_version=6.0.0_bcb87fa-dirty_2019.05.07 [64-bit] [MP]
>   NC_GLOBAL#history=img2grd -R-180/180/-80/80 topo_19.1.img
> -Gspherical-mercator-proj.grd -T1 -D -M -C
>   NC_GLOBAL#node_offset=1
>   NC_GLOBAL#title=Data from Altimetry
>   x#actual_range={-20037148.3427892,20037868.3427892}
>   x#long_name=x_units
>   y#actual_range={-15540200.914741,15540200.914741}
>   y#long_name=y_units
>   z#actual_range={-10914,8550}
>   z#grid_mapping=grid_mapping
>   z#long_name=meters, mGal, Eotvos, micro-radians or Myr, depending on img
> file and -S.
>   z#_FillValue=-1.#IND
> Corner Coordinates:
> Upper Left  (-20037148.343,15540200.915) (179d59'48.36"W, 80d 0' 8.37"N)
> Lower Left  (-20037148.343,-15540200.915) (179d59'48.36"W, 80d 0' 8.37"S)
> Upper Right (20037868.343,15540200.915) (179d59'48.36"W, 80d 0' 8.37"N)
> Lower Right (20037868.343,-15540200.915) (179d59'48.36"W, 80d 0' 8.37"S)
> Center      (     360.000,       0.000) (  0d 0'11.64"E,  0d 0' 0.01"N)
> Band 1 Block=21600x1 Type=Float32, ColorInterp=Undefined
>   NoData Value=nan
>   Metadata:
> file and -S.
>     NETCDF_VARNAME=z
>     _FillValue=-1.#IND
> Joaquim
> (with Paul’s help for the scaling factor)
> *From:* PROJ <proj-bounces at lists.osgeo.org> *On Behalf Of *Kurt Schwehr
> *Sent:* Tuesday, May 7, 2019 10:52 PM
> *To:* PROJ <proj at lists.osgeo.org>
> *Subject:* [PROJ] Projection for Sandwell et al.'s topex topo and grav
> files?
> Hi all,
> I figured I should ask here too if anyone know what the correct projection
> is for the Sandwell .img grids from http://topex.ucsd.edu.  I'm trying to
> keep the files in their original projections as I switch them to geotiffs.
> I've asked David Sandwell directly too if he knows.
> This works, but warps the data first:
> gmt img2grd -V -R-180/180/-80/80 topo_18.1.img  -Gtest2.grd -T1 -D
> gdal_translate -a_srs EPSG:4326 test2.grd test2.tif
> gdalinfo test2.tif  # Results look believable
> gdal_translate topo-18-1-epsg4326.tif topo-18-1-epsg4326-deflate.tif -co
> COMPRESS=DEFLATE -co PREDICTOR=3
> Then imported into QGIS or Earth Engine as a normal user, things line up
> pretty well.
>     https://code.earthengine.google.com/f43c8b13bafa26fd8c7f83ce9a919f6e
> I'd rather do it more like this:
> img2grd: Expects topo_18.1.img to be 21600 by 17280 pixels spanning
> 0/360.0/-80.738009/80.738009.
> img2grd: To fit [averaged] input, your topo_18.1.img is adjusted to
> -R-180/180/-80.0023237126/80.0023237126.
> img2grd: The output grid size will be 21600 by 16752 pixels.
> img2grd: Created 21600 by 16752 Mercatorized grid file.  Min, Max values
> are -10914  8550
> gives this which doesn't work as is:
> Coordinate System is `'
> Origin = (0.000000000000000,279.199999999999989)
> Pixel Size = (0.016666666666667,-0.016666666666667)
> Metadata:
>   NC_GLOBAL#Conventions=COARDS, CF-1.5
> -R0/360/-80.0023237126/80.0023237126
>   NC_GLOBAL#GMT_version=5.4.3 (r19528) [64-bit]
> Should I be using one of 54004 or 41001?  e.g.
> https://epsg.io/?q=spherical+mercator
> Thanks!
> -kurt
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190508/cbc21120/attachment-0001.html>
More information about the PROJ mailing list
