[PROJ] Definition of EPSG:4164
Even Rouault even.rouault at spatialys.com
Sun May 12 18:46:10 PDT 2019
On lundi 13 mai 2019 08:38:47 CEST Nyall Dawson wrote:
> Hi list,
> On proj master, running "projinfo EPSG:4164" results in the output (as
> expected) of:
> PROJ.4 string:
> +proj=longlat +ellps=krass +towgs84=-76,-138,67,0,0,0,0 +no_defs +type=crs
> Yet, running the code:
> PJ* crs = proj_create_from_database( 0, "EPSG", "4164",
> PJ_CATEGORY_CRS, false, nullptr );
> const char* projstring = proj_as_proj_string( 0, crs, PJ_PROJ_4, nullptr);
> results in "+proj=longlat +ellps=krass +no_defs +type=crs", with no
> towgs84 param.
> What am I missing here?
projinfo does indeed a little more work by calling
proj_crs_create_bound_crs_to_WGS84() which makes en effort to retrieve a
towgs84 clause when it is possible to add one (this one is defined in
proj_experimental.h, which should rather be understood as "proj advanced")
first.
Even
http://www.spatialys.com
More information about the PROJ mailing list
