[PROJ] How to match a proj string to the db?
Even Rouault even.rouault at spatialys.com
Sun May 12 18:54:30 PDT 2019
On dimanche 12 mai 2019 20:25:52 CEST Nyall Dawson wrote:
> PJ* crs = proj_create( 0, "+proj=longlat +datum=WGS84 +no_defs +type=crs")
> if ( PJ_OBJ_LIST *crsList = proj_identify( 0, crs, nullptr, nullptr,
> &confidence ) )
>  // never reached, regardless of proj string
Hum, works for me. Is PROJ_LIB properly set ?
> What about the "hard-coded" part of the text? What exactly does this
> mean? I can't see anyway to specify this list of hard-coded
> candidates.
No, it means that there are a few CRS whose definitions is hard coded and so
identify() might be able to identiy them even if the database is not
available. But you can ignore that implementation detail.
http://www.spatialys.com
More information about the PROJ mailing list
