[PROJ] Converting coordinates between different ellipsoids... possible? valid?
Even Rouault even.rouault at spatialys.com
Mon May 20 00:45:27 PDT 2019
On lundi 20 mai 2019 13:15:55 CEST Nyall Dawson wrote:
> Hey list,
> If I attempt to create a transform using proj_create_crs_to_crs, with
> the source proj string "+proj=longlat +datum=WGS84 +no_defs" and dest
> proj string "+proj=longlat +a=2632345 +no_defs", I get the error
> "internal_proj_create_operations: Source and target ellipsoid do not
> belong to the same celestial body".
> My question is -- should this be allowed? It worked ok in previous
> proj versions, and it's a common situation in QGIS
Not for real world use cases, but for some artificial unit cases, right ?
> Or is it violating some rule of transformation? How can I reproduce
> the proj 4 behaviour here?
I think we discussed this before. Basically there's a new check that prevents
doing non sensical transformations. No workaround than disabling the check in
code
Even
http://www.spatialys.com
More information about the PROJ mailing list
