[PROJ] PROJ.6 6.1.0 on macOS 10.14 w/o pkgsrc
David Fogel multiquadric at gmail.com
Tue May 28 15:44:27 PDT 2019
Thought to share a build experience with PROJ.6 6.1.0 on macOS Mojave
(10.14) natively. A change in "configure" was required. I also passed
extra variables to "configure". Let's call this a sanity check ahead of
a bug report? Soonest I can generate diffs is at then end of this week.
In "configure" the test for the presence/absence of SQLite3 seems to
always fail. In other words, absent pkgsrc, regardless of whether
SQLITE3_CFLAGS and SQLITE3_LIBS are defined or not, the results are the
same.  I have not, yet, installed pkgsrc.
To successfully compile, I also had to tease the right results out of
configure. Notably, I pointed to SQLite3 twice.
$ ./configure -prefix=/opt/proj-6.1.0
SQLITE3_CFLAGS=-I/opt/sqlite-3.28.0/include
SQLITE3_LIBS=-L/opt/sqlite-3.28.0/lib -lsqlite3 CC=gcc -arch x86_64
CXX=g++ -arch x86_64 CPP=gcc -E CXXCPP=g++ -E
CPPFLAGS=-I/opt/sqlite-3.28.0/include LDFLAGS=-L/opt/sqlite-3.28.0/lib
-lsqlite3
Other subtleties may not apply, such as the SQLite3 build.
Tests passed.
If the "tests" for pkgsrc, and then SQLITE3_CFLAGS and SQLITE3_LIBS
definitions failed on macOS, then it is possible they will fail on
"Unix/Linux" as well. Possible? Plausible?
Thanks,
= David
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190528/b44daf45/attachment.html>
More information about the PROJ mailing list
