[PROJ] Has anyone build PROJ on Windows? Could I pay you to show me how?
J Luis jmfluis at gmail.com
Wed May 29 02:43:20 PDT 2019
Craig,
I build sqlite with these commands. Please find attached the .def file that
you'll also need
cl /c sqlite3.c /nologo /MD /Ox /DSQLITE_ENABLE_COLUMN_METADATA
/DSQLITE_ENABLE_RTREE
link /out:sqlite3.dll /implib:sqlite3.lib /def:sqlite3.def /dll
/MACHINE:X64 sqlite3.obj
Joaquim
On Wed, May 29, 2019 at 7:36 AM Roger Oberholtzer <
roger.oberholtzer at gmail.com> wrote:
> I maintain proj for multiple platform on the opensuse build service. There
> is a 64- and 32-bit build for windows. I use it in my own software. Look at
> build.opensuse.org. Btw, there are also builds of 6.1.0 for many Linux
> versions maintained by me there. A windows build will arrive shortly
> (time...).
> You can search the site for packages. I can send a direct link when I’m
> back in the office if that fails.
> Roger
> On 29 May 2019, at 05:49, Craig Delancy <
> cdelancy at blackfangtechnologies.com> wrote:
> I am desperately trying to build GDAL 3.0 on windows. PROJ4 6.0 is
> required. Because I cannot build PROJ, I cannot build GDAL. I am willing to
> pay for someone to join me in a Skype or Discord call, and give me
> instructions. Name your price.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190529/0655a830/attachment-0001.html>
EXPORTS
sqlite3_aggregate_context
sqlite3_aggregate_count
sqlite3_auto_extension
sqlite3_backup_finish
sqlite3_backup_init
sqlite3_backup_pagecount
sqlite3_backup_remaining
sqlite3_backup_step
sqlite3_bind_blob
sqlite3_bind_blob64
sqlite3_bind_double
sqlite3_bind_int
sqlite3_bind_int64
sqlite3_bind_null
sqlite3_bind_parameter_count
sqlite3_bind_parameter_index
sqlite3_bind_parameter_name
sqlite3_bind_pointer
sqlite3_bind_text
sqlite3_bind_text16
sqlite3_bind_text64
sqlite3_bind_value
sqlite3_bind_zeroblob
sqlite3_bind_zeroblob64
sqlite3_blob_bytes
sqlite3_blob_close
sqlite3_blob_open
sqlite3_blob_read
sqlite3_blob_reopen
sqlite3_blob_write
sqlite3_busy_handler
sqlite3_busy_timeout
sqlite3_cancel_auto_extension
sqlite3_changes
sqlite3_clear_bindings
sqlite3_close
sqlite3_close_v2
sqlite3_collation_needed
sqlite3_collation_needed16
sqlite3_column_blob
sqlite3_column_bytes
sqlite3_column_bytes16
sqlite3_column_count
sqlite3_column_database_name
sqlite3_column_database_name16
sqlite3_column_decltype
sqlite3_column_decltype16
sqlite3_column_double
sqlite3_column_int
sqlite3_column_int64
sqlite3_column_name
sqlite3_column_name16
sqlite3_column_origin_name
sqlite3_column_origin_name16
sqlite3_column_table_name
sqlite3_column_table_name16
sqlite3_column_text
sqlite3_column_text16
sqlite3_column_type
sqlite3_column_value
sqlite3_commit_hook
sqlite3_compileoption_get
sqlite3_compileoption_used
sqlite3_complete
sqlite3_complete16
sqlite3_config
sqlite3_context_db_handle
sqlite3_create_collation
sqlite3_create_collation_v2
sqlite3_create_collation16
sqlite3_create_function
sqlite3_create_function_v2
sqlite3_create_function16
sqlite3_create_module
sqlite3_create_module_v2
sqlite3_data_count
sqlite3_data_directory
sqlite3_db_cacheflush
sqlite3_db_config
sqlite3_db_filename
sqlite3_db_handle
sqlite3_db_mutex
sqlite3_db_readonly
sqlite3_db_release_memory
sqlite3_db_status
sqlite3_declare_vtab
sqlite3_enable_load_extension
sqlite3_enable_shared_cache
sqlite3_errcode
sqlite3_errmsg
sqlite3_errmsg16
sqlite3_errstr
sqlite3_exec
sqlite3_expanded_sql
sqlite3_expired
sqlite3_extended_errcode
sqlite3_extended_result_codes
sqlite3_file_control
sqlite3_finalize
sqlite3_free
sqlite3_free_table
sqlite3_get_autocommit
sqlite3_get_auxdata
sqlite3_get_table
sqlite3_global_recover
sqlite3_initialize
sqlite3_interrupt
sqlite3_last_insert_rowid
sqlite3_libversion
sqlite3_libversion_number
sqlite3_limit
sqlite3_load_extension
sqlite3_log
sqlite3_malloc
sqlite3_malloc64
sqlite3_memory_alarm
sqlite3_memory_highwater
sqlite3_memory_used
sqlite3_mprintf
sqlite3_msize
sqlite3_mutex_alloc
sqlite3_mutex_enter
sqlite3_mutex_free
sqlite3_mutex_leave
sqlite3_mutex_try
sqlite3_next_stmt
sqlite3_open
sqlite3_open_v2
sqlite3_open16
sqlite3_os_end
sqlite3_os_init
sqlite3_overload_function
sqlite3_prepare
sqlite3_prepare_v2
sqlite3_prepare_v3
sqlite3_prepare16
sqlite3_prepare16_v2
sqlite3_prepare16_v3
sqlite3_profile
sqlite3_progress_handler
sqlite3_randomness
sqlite3_realloc
sqlite3_realloc64
sqlite3_release_memory
sqlite3_reset
sqlite3_reset_auto_extension
sqlite3_result_blob
sqlite3_result_blob64
sqlite3_result_double
sqlite3_result_error
sqlite3_result_error_code
sqlite3_result_error_nomem
sqlite3_result_error_toobig
sqlite3_result_error16
sqlite3_result_int
sqlite3_result_int64
sqlite3_result_null
sqlite3_result_pointer
sqlite3_result_subtype
sqlite3_result_text
sqlite3_result_text16
sqlite3_result_text16be
sqlite3_result_text16le
sqlite3_result_text64
sqlite3_result_value
sqlite3_result_zeroblob
sqlite3_result_zeroblob64
sqlite3_rollback_hook
sqlite3_rtree_geometry_callback
sqlite3_rtree_query_callback
sqlite3_set_authorizer
sqlite3_set_auxdata
sqlite3_set_last_insert_rowid
sqlite3_shutdown
sqlite3_sleep
sqlite3_snprintf
sqlite3_soft_heap_limit
sqlite3_soft_heap_limit64
sqlite3_sourceid
sqlite3_sql
sqlite3_status
sqlite3_status64
sqlite3_step
sqlite3_stmt_busy
sqlite3_stmt_readonly
sqlite3_stmt_status
sqlite3_strglob
sqlite3_stricmp
sqlite3_strlike
sqlite3_strnicmp
sqlite3_system_errno
sqlite3_table_column_metadata
sqlite3_temp_directory
sqlite3_test_control
sqlite3_thread_cleanup
sqlite3_threadsafe
sqlite3_total_changes
sqlite3_trace
sqlite3_trace_v2
sqlite3_transfer_bindings
sqlite3_update_hook
sqlite3_uri_boolean
sqlite3_uri_int64
sqlite3_uri_parameter
sqlite3_user_data
sqlite3_value_blob
sqlite3_value_bytes
sqlite3_value_bytes16
sqlite3_value_double
sqlite3_value_dup
sqlite3_value_free
sqlite3_value_int
sqlite3_value_int64
sqlite3_value_nochange
sqlite3_value_numeric_type
sqlite3_value_pointer
sqlite3_value_subtype
sqlite3_value_text
sqlite3_value_text16
sqlite3_value_text16be
sqlite3_value_text16le
sqlite3_value_type
sqlite3_version
sqlite3_vfs_find
sqlite3_vfs_register
sqlite3_vfs_unregister
sqlite3_vmprintf
sqlite3_vsnprintf
sqlite3_vtab_collation
sqlite3_vtab_config
sqlite3_vtab_nochange
sqlite3_vtab_on_conflict
sqlite3_wal_autocheckpoint
sqlite3_wal_checkpoint
sqlite3_wal_checkpoint_v2
sqlite3_wal_hook
sqlite3_win32_is_nt
sqlite3_win32_mbcs_to_utf8
sqlite3_win32_mbcs_to_utf8_v2
sqlite3_win32_set_directory
sqlite3_win32_sleep
sqlite3_win32_unicode_to_utf8
sqlite3_win32_utf8_to_mbcs
sqlite3_win32_utf8_to_mbcs_v2
sqlite3_win32_utf8_to_unicode
sqlite3_win32_write_debug
More information about the PROJ mailing list
