[PROJ] Announcing PROJ 6.2.1
Kristian Evers kreve at sdfe.dk
Fri Nov 1 11:50:24 PDT 2019
On behalf of the PROJ development team I am happy to announce the
release of PROJ 6.2.1.  See release notes below for details.
Download the source distribution here:
https://download.osgeo.org/proj/proj-6.2.1.tar.gz (https://download.osgeo.org/proj/proj-6.2.1.tar.gz.md5)
https://download.osgeo.org/proj/proj-6.2.1.zip (https://download.osgeo.org/proj/proj-6.2.1.zip.md5)
6.2.1 Release Notes
 Updates
 o Update the EPSG database to version 9.8.2
 Bug fixes
 o Fixed erroneous spelling of "Potsdam" (#1573)
 o Calculate y-coordinate correctly in bertin1953 in all cases (#1579)
 o proj_create_crs_to_crs_from_pj(): make the PJ* arguments const PJ* (#1583)
 o PROJStringParser::createFromPROJString(): avoid potential infinite
   recursion (#1574)
 o Avoid core dump when setting ctx==NULL in functions
   proj_coordoperation_is_instantiable and
   proj_coordoperation_has_ballpark_transformation (#1590)
 o createOperations(): fix conversion from/to PROJ.4 CRS strings with
   non-ISO-kosher options and +towgs84/+nadgrids (#1602)
 o proj_trans_generic(): properly set coordinate time to HUGE_VAL when no
   value is passed to the function (#1604)
 o Fix support for +proj=ob_tran +o_proj=lonlat/latlong/latlon instead of only
   only allowing +o_proj=longlat (#1601)
 o Improve backwards compatibility of vertical transforms (#1613)
 o Improve emulation of deprecated +init style initialization (#1614)
 o cs2cs: autopromote CRS to 3D when there's a mix of 2D and 3D (#1563)
 o Avoid divisions by zero in odd situations (#1620)
 o Avoid compile error on Solaris (#1639)
 o proj_create_crs_to_crs(): fix when there are only transformations with
   ballpark steps (#1643)
 o PROJ string CRS ingester: recognize more unit-less parameters, and general
   handling of +key=string_value parameters (#1645)
 o Only call pkg-config in configure when necessary (#1652)
 o aeqd: for spherical forward path, go to higher precision ellipsoidal
   case when the point coordinates are super close to the origin (#1654)
 o proj_create_crs_to_crs(): remove elimination of Ballpark operations
   that caused transformation failures in some cases (#1665)
 o createOperations(): allow transforming from a compoundCRS of a bound
   verticalCRS to a 2D CRS (#1667)
 o Avoid segfaults in case of out-of-memory situations (#1679)
 o createOperations(): fix double vertical unit conversion from CompoundCRS
   to other CRS when the horizontal part of the projected CRS uses non-metre
   unit (#1683)
 o importFromWkt(): fix axis orientation for non-standard ESRI WKT (#1690)
More information about the PROJ mailing list
