[PROJ] Needs a sanity check on Vertical Transformation
YK_climate julien.schroder at gmail.com
Fri Nov 1 13:12:11 PDT 2019
Hello,
I have been trying to perform vertical transformation with Proj for a few
days now, I think I am done but I am in some help to be sure I didn't make
some stupid mistakes!
I am looking at getting coordinates in WGS84-Ellipsoid to WG84-EGM96,WG84-
EGM2008 and to NAD83(2011)GEOID12B.
Here is what I have working so far :
WGS84-EGM2008 : cs2cs EPSG:4979 EPSG:4326+3855
WGS84-EGM96    : cs2cs EPSG:4979 EPSG:4326+5773
Is this correct?
So naturally I thought that GEOID12B would be as easy :
NAD83(2011)-GEOID12B    : cs2cs EPSG:4979 EPSG:6319+5703 <= no vertical
change
NAD83(2011)-GEOID12B    : cs2cs EPSG:4979 EPSG:5498         <= no vertical
change
After reading about geoidgrids I tried this and it works but I need to be
sure I am using the right parameters
cs2cs EPSG:4979 "+proj=longlat +datum=NAD83 +geoidgrids=g2012bu0.gtx"
Thank you for your time!
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
More information about the PROJ mailing list
